miele washing machine w562 prestige plus 6
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries miele washing machine w562 prestige plus 6
  • #51592
    dealdd
    been out to this miele and found the anti flood tray full, so i drained it off and run it up. i found it starts to fill through the hose on door seal then stops to let the dispenser change to fill through the soap draw. when it does this the water distributer moves from position 1 to position 3 then stops for 20 seconds, then the water inlet light comes on and 5 second later carries on filling in position 3. i have checked the distributer over and all contacts in side seem ok, pressure chamber is clear i think its the pcb. has any one got some sugestions or and test mode for this machine as pcb will be expensive and i want to check everything first
    #308682
    Seamy
    Re: miele washing machine w562 prestige plus 6
    might be that its not reaching right position on dispenser in time, if you look down on the top of dispenser you will see the positions it should go to, it takes water onto door for a few seconds to assure the customer that water is going in, it then moves to soap drawer, it will time out after a few seconds if it doesnt reach correct position, these times can be extended by the way.
    #308683
    dealdd
    it is going to the position three straight away, so that seems ok. do you know how to extend the times??
    #308684
    dealdd
    has any one got any paper work on the machines??
