Miele Professional PW6055
I have just replaced the water inlet valve to remedy a problem: the machine was not filling with water at the beginning and the message “Water inlet fault. Open the stopcock and check the inlet hose.” was coming up 5 minutes into the cycle.
The fresh valve has stopped this – water comes in normally right at the start of the wash. The machine washes the clothes no problem. But then just at the start of the final rinse/fabric conditioner cycle (last cycle before spin) the machine drains and the “Water inlet fault” reappears. It does not progress after this.
The strange (and maddening) thing is that it only does this WITH CLOTHES in it – when you run the wash program without clothes there are no faults and the cycles continue unimpeded.
What on earth is the issue? I am stumped.
Could the drain hose be too far down the waste pipe or is there a water pressure problem?
Any ideas appreciated and mulled over.
(I will mention that the valve I relaced the old one with is second hand and not brand new. Would a brand new valve remedy the situation?)
Alex, Tottenham
