I have a Miele W3444WPS.
My son knocked the discharge hose out of the machine and it activated the watter protection system.
When you turn it on both the check inlet and check drain lights flash and
“—” appears in the display.
Does anyone know how to reset it
There is a solid bottom to this machine below the drum. On it is a float unit, I would imagine water from the hose bein displaced has leaked in there and activated said float.
You will need to remove this water and thus allow float to return to normal position.
Always unplug appliance before attempting any repair. :plug:
Thanks for that.
I thought that no water had got into the bottom of the machine but it had
I had trouble removing the side or the back but managed to tip the machine on it’s side to clear the water and it reset OK
Thanks again
and I’m glad I spent the money on a good machine with water protection otherwise the who house would have been flooded.
