Miele WDA211 – Ticking noise
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele WDA211 – Ticking noise
  • #96625
    MrsWorm
    Hi folks, need some advice. I have a 3 year old Miele WDA211 which is making a ticking/clicking noise when I switch it on and select a programme (like an old mechanical timer would make).
    I’ve only just noticed this and it’s working fine but I wondered if it’s a sign of impending doom or whether I should just carry on as normal and ignore it.
    Any advice appreciated. Thanks.
    #464153
    a lot of miele machines have a small motor at the back of the soap draw to direct the water where its needed
    its likely this is what you can hear and its normal
    in a lot of machines it will fill a bit, then you hear the ticking noise, then it fills again
    MrsWorm
    Dave thanks for your reply. It’s ticking from the minute that you power it on but as I say, it’s still working perfectly well 🙂
    #464155
    turn on the power and see if it starts ticking
    if yes leave it 2 to 3 mins and see if it stops
    if yes then it is the draw moving to the start position
