Home › Forums › Public Support Forums › General Enquiries And Questions › Miele WM Problem – screech, spins then faults
- This topic has 6 replies, 2 voices, and was last updated 4 years, 7 months ago by
Ambienz.
August 17, 2021 at 9:30 am #99946
Ambienz
ParticipantHello all,
I have an issue with a Miele Washing Machine. W5800 Model.
Only happened when returned from holidays. Worked flawlessly up until that point.
Initially when loaded it would start the fill cycle then stop after 30s. Complete power cut off that required device unplug, reset and restart. No fuse tripping etc.
Water inlet and outlet seem to be fine – no blockages.
Cleaned out filters and found black sediment in there. Some quite firmly attached to the plastic filter housing. This suggested possible bearings, but they seem ok. After the screech it spins fine. When lose there is no play in the drum to suggest bearing problem.Now the issue has evolved. When machine switched on with door closed (unloaded), it makes a screeching sound, starts spinning and the displays TECHNICAL FAULT message.
I think these are direct drive so no loose belts.
Switching on machine with door open, it starts up as usual and displays cycle options in LED screen. However once door is closed, the spin cycle and fault routine starts again.
Door lock seems to be OK as it is the trigger to start the spin cycle.
Does anyone know why the machine is triggering a spin cycle on start, or what the likely cause of this initial short noise is?
The initial cut off problem suggested possible PCB component issue, but as this quickly changed to the spinning and fault message, perhaps otherwise.
David
August 17, 2021 at 7:44 pm #478593electrofix
Moderatorsounds like the motor is spinning out of control
could be board or motor problem
there is a small generator on the back of the motor. this feeds motor speed to the board. Either thats broken. the wires to the board are broken or the motor control triac is faulty
August 18, 2021 at 7:46 am #478594Ambienz
ParticipantThanks for your reply Dave,
OK a few things to investigate. Be nice it if was as simple as the wires.
As this is not an area i am familiar with, I assume that on startup the PCB runs various component tests, and in this case the test for the motor is causing it to start spinning which feeds back an error?
The fact that there is a screeching sound, only when the motor starts spinning suggests that there is a friction between the drum spinning and something else. The drum spins freely, but could it still be a bearing issue?
If not – what else are possible causes. Are these carbon brush motors and could they need replacing?
Cheers
David
August 18, 2021 at 8:52 am #478595electrofix
Moderatorimagine you in your car with medium engine revs and take you foot off the clutch too fast, same problem here
the motor is accelerating too fast, does sound like a board fault. If it was me i would remove the board and check a component called a Triac. these are used in lots of things to control power. If you call miele they just fit a complete board and you will not like the price
you can seach testing triac for some clues
the tacho on the motor can be checked with a multimeter. first you have to find the correct connections then you can set the meter on a low ac volt scale and spin the motor and look for an output
August 18, 2021 at 9:26 am #478596Ambienz
ParticipantThanks again Dave,
All makes perfect sense.
The only thing that I am confused with is why the motor starts spinning when the unit is turned on with the door shut, as opposed to starting a cycle when I expect the motor to turn.
Cheers
August 18, 2021 at 9:54 am #478597electrofix
Moderatorthat then makes it certain its a board fault as with tacho failure that cant happen
August 18, 2021 at 9:59 am #478598Ambienz
ParticipantThat is a great help.
Thank you Dave
