Miele wont start
  • #9977
    Kirk
    I have a call wed to one, all I know is that it is a PREM 300?
    The fault is it won’t switch on? any help would be a welcome.
    Kirk
    #137055
    Re: Miele wont start
    There’s a moving lever inside the door lock which seems to break sometimes and therefore doesn’t work the switch.
    Seamy
    Premier 300 is a range of machines (includes 300,301,302 etc) model num’ is reguired W304 for instance, door interlock for this range is (part num’ 4842084), about £35ish trade. Try also faulty on/off start switch (5869690 part num’) £25ish trade, small electronic card located on rhs of facia panel.
    Worthwhile checking for water in sump of machine if its a 308 as some of the 300 series have a closed sump & float switch mechanism, this will give a red LED fault (waterintake).
    #137057
    Kirk
    Thanks for your help Kirk
