Miele WS5426 push button unit keeps blowing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele WS5426 push button unit keeps blowing
  • #59951
    conormccleane
    Push button unit (5 button-type) blown solder tracks on terminal connection 19 (from door lock), terminal connection 18 also seems charred (from power electronic). Fitted replacement and it popped again, same place. Anyone come across this before? Can tracking be resoldered? Is door lock causing this?
    Conor!
    #340195
    Re: Miele WS5426 push button unit keeps blowing
    conormccleane wrote: Anyone come across this before? Can tracking be resoldered? Is door lock causing this?
    Conor!
    1. I haven’t 2. Probably, but could be fiddly. 3. Quite likely. Suggest remove it (the lock) dismantle and examine. Better remove and examine electronic as well, as that may be damaged. Sounds like it could end up seriously expensive. Definitely don’t buy more parts till you’re sure you’ve understood the problem.
    Mike.
    #340196
    jeremy
    hole in top of door seal is known to blow the switch bank assy , doesnt have to be a very big hole either !
    #340197
    conormccleane
    Door lock faulty – replaced with recovered unit – also had a spare pushbutton unit – sorted.
    #340198
    dealdd
    sounds like door lock but i did catch wire to door lock once when doing up the 3 bolts around door seal. this blew track on board so i soldered wire straight to it and worked fine. if you havent changed lock i would do that first and inspect loom when you change it
