miele ws5426 washer manual
  • #24226
    robbieh
    Has anyone got a instruction or service manual for this washing machine that could be emailed?
    Many thanks Robbie
    #201194
    Seamy
    Re: miele ws5426 washer manual
    Whats the problem you are encountering with it? post it & maybe someone can be of help to you.
    #201195
    robbieh
    Manual received courtesy of clayside many thanks much appreciated!
    I will be testing this machine in the next few days the customer said it does not allways select the right programme and sometimes sticks on the previous but i await to see.
    Many thanks
    Robbie
    #201196
    Seamy
    All Miele machines have circuit diagram inside the machine unless someone has ncked it before.
    Miele machines (normally) remember the last used programme & save those settings eg, temp, spin speed, water level etc.
    Many problems arise by customers not realising this or simply not reading the instruction book.
    This machine mentioned is a semi-commercial, known as “little giant”, i’ve encountered knob inner breakages in these which may cause fault mentioned.
    #201197
    robbieh
    Many thanks
    Machine now fixed, it turned out to be edge connectors not making contact
    Robbie
