Re: Miele WT2670 Cant get in it!!!!
front off and then side panels.
single bolt at 6 oclock under door, pull off kick strip (maybe retained by 2 screws under caps) undo the 2 outer screws under the front lip of front now exposed once kick strip is removed. Carefully push down front panel to remove ITs Heavey!
screws down the front of each side panel can now be seen, revmove lid (2 screws under caps on the side towards the front and 2 at rear), more side panel screws at rear and along top under the lid, and sides then fall off.
would imagine that will have a moulded mains terminal affair though £££
