Miele WT2670 – Good choice ???
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele WT2670 – Good choice ???
Viewing 15 posts - 1 through 15 (of 17 total)
  • #15130
    oldfield_ian
    Firstly, thank you to those who advised prior to the demise of a brand new Hotpoint Washer/Dryer. Three scratched doors later its going back!
    Now I have in mind to replace it with a Miele WT2670 Washer/Dryer. Is this a good choice? There seems to be a lot of praise for Miele on the forum.
    I see some comments that advise on using an ‘independant’ local retailer rather than the WWW. If you are one of them and would like to supply the above machine at £815 (or less) inc VAT and delivery, let me know! If you think I am taking the proverbial take a look at http://www.qed-uk.com
    The machine has a manufacturer covered warranty for five-years, so spare the rhetoric on the benefits of after-sales service, etc. I do not wish to appear rude to those of you who kindly offer advise on here and are trying to make a living through shop retail, but when the difference in price is several hundred pounds, the local service would have to be quite something to justify the difference.
    Kind Regards
    Ian.
    #162229
    gegsy
    Re: Miele WT2670 – Good choice ???
    Miele = Rolls Royce
    Need we go on
    Oh come on Gegsy……..
    Miele = Mercedes Benz 😀
    This is the 21st Century after all…………….
    gegsy
    Ok 20th century 😀
    Bosch = Saab
    Miele = Lexus
    Indesit = (runs with nauseus developments)
    Greg 😆
    #162232
    Goatboy
    Ahem! 😀
    Siemens WXD1260
    Goatboy will do you one for £600ish 😉
    If Miele = Merc
    Then Siemens = Bentley, or maybe Volvo 😕
    #162233
    oldfield_ian
    “Siemens WXD1260 – Goatboy will do you one for £600ish “
    What a gent! I’ll do you one for £550, including a large box of washing powder and a bunch of flowers.
    Now, do you know anything useful about the Miele WT2670, or is this forum your shop window?
    Ian.
    #162234
    gegsy
    oldfield_ian wrote:Now, do you know anything useful about the Miele WT2670, or is this forum your shop window?
    Ian.
    Design
    Straight fascia
    Extra large door opening (30cm)
    Unique Miele honeycomb drum
    Max. load 5 kg washing / 2.5 kg drying
    Easily accessible filter, direct enamel casing
    Removable front and sides for servicing
    Drum Lighting
    Controls
    Single programme selector switch with button to select washing, drying or washing and drying in a continous sequence
    Large clear text display showing programme selection, duration, start and end time as well as fault and error messages
    Programme delay up to 24 hours
    Buzzer at end of programme (with button)
    PC update facility
    Sound insulation
    Extemely quiet with special sound insulation
    Additional functions
    Soak, pre-wash, short, water plus
    Safety features
    Fully electronic child resistant controls
    Electronic programme locking and system lock with locked indicator
    Waterproof system with metallic hose
    Extensive maintenance and warning and fault messages in the display for users
    Fault diagnosis programme for service engineers
    Washing
    Various temperatures selectable
    Spin speeds from 400 to 1600 rpm
    Rinse hold and without spin options
    Gentle run up to spin, imbalace check
    Cottons, Minimum iron, Delicates, Automatic, Express, Handwashable woollens, Silks, Denim, Shirts,
    Dark garments, Sportswear, Outerwear, Proofing, Curtains, Separate rinse, Starch
    Environment friendly washing Automatic load adjustment with fuzzy logic for saving water, electricity and time
    Automatic foam sensing and control
    Programmable functions
    Choice of language, 12 h or 24 h clock, Water plus system, gentle action, automatic suds cooling, door release
    distribution controller, alter drying time, system lock, memory, buzzer and keypad tones, display contrast and brightness,
    standby and extended cool down
    Drying
    Cottons, Minimum iron, Delicates, Automatic, Express, Handwashable woollens, Denim, Shirts
    Dark garments, Sportswear, Outerwear, Proofing, Smoothing, Timed drying warm air or cool air
    15 min – 2 h
    Automatic lint flush cycle
    Installation
    Freestanding
    Can be built under (special kit required)
    H x W x D: 85 x 59.5 x 58 cm
    Hope thats of some use to you 😉
    I think we may have it the wrong way round after that little exposition:
    Mercedes Benz = Miele!
    Seriously for a moment, excellent machines – your kids will probably be able to inherit it.
    Goatboy
    oldfield_ian wrote:…or is this forum your shop window?
    Just trying to offer a viable alternative to the overpriced Miele. The Siemens is a fantastic machine. ‘A’ rated wash, 1200 spin, 2 year guarantee, LED display, and a time remaining display.
    If you don’t like getting FREE advice then you should stick that Miele…
    You wanna know how much money I’ve made from this forum? Same as everyone else, NOTHING! We’re just giving free advice. Most people would take that model number I gave you, and do something usefull with it, but you just insult me!?!?!?!?! Typical Merc driver!
    Would you like a pound of flesh too?
    (Edited, because Goatboy is a pillock!)
    #162237
    oldfield_ian
    Dear Goatboy
    I am sorry if you feel offended. Certainly, your posting is offensive and clearly intended as such. If that is your idea of helpful, free advice, it is not mine.
    I merely asked if you knew something useful about the specific machine I enquired about, such as gegsy has kindly done, albeit, its a lift of the product spec. Your posting did not even refer to my original question, you simply offered to sell me something else – no thanks.
    If I wanted a Siemens, I could buy one and have it delivered for £505. I am interested in the Miele WT2670. If you know something about the reliability of this machine, please feel free to share your ‘free advice’.
    I realise many of you help us without making money and I for one am grateful. But, you suggested selling me a machine for about £95 more than I can get it for and didn’t even mention the Miele, so frankly that’s the sort of ‘free’ advice I don’t need.
    By the way, I have now purchased a Miele from a local retailer, who was helpful, polite and able to offer a competitive price.
    Thank you to all those who have offered helpful comments.
    Ian.
    #162238
    Goatboy
    Sorry about the outburst Ian, I get very grumpy in the morning. 😕
    Glad to hear that you are sorted! 🙂
    Ps. The general rule with Kelkoo, is that the people selling it the cheapest, don’t have the stock, but can offer an alternative. And £600 off me, includes installation and disposal of the old machine, and I have them in stock; but as you can see, i need to work on my customer service.
    #162239
    gegsy
    oldfield_ian wrote:
    albeit, its a lift of the product spec. Ian.
    What better way to get accurate specifications for your perusal 😉
    oldfield_ian
    Quite agree, thank you for the information. I was really trying to find out if those of you in the business (selling / servicing / repair) had any comments about the Miele in terms of reliability / problems. It seems there is general agreement they are fine machines. Of course, it will have to pass the wife test!
    Thank you all again for your comments, and to Goatboy, no problem. If you think you’re grumpy in the morning ….. 🙁
    All the best.
    Ian.
    #162241
    gegsy wrote:
    Ian.
    Drum Lighting……………………. blah blah ………
    ……………Automatic lint flush cycle.
    Not much to go wrong there then. 😈 😛 (Excuse my ignorance, what does Razz mean?)
    Me, I say “Keep it simple”.
    Mike.
    #162242
    Actually, a remarkabley simple machine and astonishingly reliable. A solid, well made appliance with electronics that don’t self destruct when you smile at them; this is reflected in the price.
    The only down side is that on the off chance that it does fail some part prices verge on the scary.
    The ones I service up here are always out in farms and country cottages. Come winter the little furry creatures come in out of the cold and nibble things they shouldn’t; so the repairs which I do do are damage, as opposed to failure.
