Miele WT2670 water in drum after dry cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele WT2670 water in drum after dry cycle
  • #91412
    Harry Raft
    Hi all, just lookinfgfor some advise really, my Miele washer dryer WT2670 has a developed a small issue. Washing is ok but drying clothes leaves the clothes soaked and steamy, almost like the machine is allowing water in the drum whilst drying. I’ve also noticed the the rinse out fluff cycle leaves water in the drum and I have to use the drain and spin cycle to remove.
    Any suggestions?, don’t mind getting stuck in to avoid the costs!
    #447975
    Re: Miele WT2670 water in drum after dry cycle
    have you cleaned the filter ?
    when the machine dries it uses a small amount of cold water to condense the steam so if this water cant drain it will fill up
    Harry Raft
    Hi yes cleaned the filter, the drain hose is 8 years old so gonna replace this to see if it helps
    #447977
    if it has not got a hole in it dont replace it
    take it off and run a hose through it, if its not clear bend is aroung to loosen crap and rinse again
    to be honest if your going to have a blockage it more likely in the sump hose
    you dont use colour catchers do you ?
    Harry Raft
    No haven’t used a colour catcher in over a year now, can I get to the sump hose to check?
    #447979
    you have to take the front off the machine
    door rubber clip off and unclip rubber
    take kick strip off
    remove screws from bottom of casing
    remove screws from door lock
    remove large single screw bottom of door
    think that’s the lot, it should pull out a but at the bottom and drop. take care to remember where the emergency door release goes
    after that you can now see under the machine to access the sump
    Harry Raft
    Would this explain why it drains fine during a normal wash and only doesn’t drain during a dry? Been using it all weekend for washing a no issue. Only drying leaves water in the drum
    #447981
    i would not have expected that. i would expect it to affect both wash and dry.
    unless the pump is overheating and shutting down.
    On wash pump is used for short bursts but on dry its used more as programme last longer
    try running a dry programme with no clothes in and see what happens. put a pan of water in the drum before you start and see if it pumps that out at the start of the programme
    Harry Raft
    Just did a quick test like you said, water was drained straight out, did a half hour dry all ok right until the very end (cool down period) when a bit of water appeared literally 10 seconds from the end seemed to drop from the top of the drum maybe????)
    #447983
    Harry Raft
    Thanks for all your advise btw
    #447984
    only thing I can think of is a faulty valve. some valve can take time to close when switched off.
    or the machine is letting water in at the end you could watch the soap draw to see if water enters from there
    my next check would be to look at the valve that is used by the dryer. you would have to disconnect the hose coming out of it and aim it into a bowl. you would then need to run the dryer till valve opens then pause machine and see if it turns off instantly
    Geoff1312
    i had problems with a miele not draining intermittently there is an air bleed hose which comes from the pump to the dispenser it was blocked so got air locks in pump and it wouldn’t drain worth a look may have to remove side panel good luck.
    geoff.
