Mini fridge makes clunking noise when compressor shuts down
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Mini fridge makes clunking noise when compressor shuts down
  • #92796
    Entario
    So I just bought the Scandomestic Cool Cube – Coca Cola mini fridge the other day. Right as I had set it up I noticed it was making a rather loud clunking sound both when turning on the cooling and turning it off. The clunking is, however, most distinct and noisy when the compressor shuts off. I have taken the liberty of recording the sound so you can hear it for yourself. I must say, I’ve never heard a fridge make such a loud sound before. It happens every 7 minutes and is loud enough to make me jump almost every time!
    https://drive.google.com/file/d/1hsyY3- … sp=sharing
    https://drive.google.com/file/d/11bqF87 … sp=sharing
    #452224
    Re: Mini fridge makes clunking noise when compressor shuts d
    Is this a new fridge?
    Is it clear of the wall at the back?
    Nothing impeding the compressor?
    #452225
    Entario
    Martin wrote:Is this a new fridge?
    It is brand new indeed. There is about 10cm from the back to the wall as suggested in the manual. Air flow should be just fine.
    #452226
    You can get that, a small stutter on compressor run start and end and more so on, shall we say, not so good compressors.
    Nothing you can do about it, it’s just the way they are.
    Entario
    kwatt wrote:You can get that, a small stutter on compressor run start and end and more so on, shall we say, not so good compressors.
    I’ve done some research and found several people describing the same clunking. Is it possible that there is a problem with the springs inside the compressor being loose and not cushioning the vibrations caused by the compressor turning on and off, thereby making the compressor parts bang against the metal side?
    #452228
    Clutching at straws a bit there. 😉
    If it were, it’d sound like someone was throwing a bag of spanners around at the back of it so, probably not, just the way they are like I said.
    Entario
    kwatt wrote:Clutching at straws a bit there. 😉
    Ah well. Just me hoping it’s an actual issue because I’ve never encountered such a loud noise coming from a fridge before. It’s quite distracting! In all the reviews I’ve found of this model, I’ve yet to come across anyone mentioning this. They all say it’s quite easy on the ears at 40db.
    Either way, thanks for the input. The company will send out a technician to check on the fridge. Apparently there is enough reason for them to question whether this is normal or not, so they’re sending him out to me free of charge.
