Misbehaving Caple 5210/1 top oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Misbehaving Caple 5210/1 top oven
  • #30355
    BunchofKeys
    Hi all – my Caple double oven is mucking about – main fan oven element blew recently – tripped the main RCCD, and was easy to spot and fix. Now the top oven’s playing up – grill works fine, ‘stat light comes on when top oven is selected but no heat.
    Seems there’s a ‘buried’ bottom element in the oven bottom – reading 46ohms; the combined top element (grill and oven I presume?) is reading 70ohms at the outside tags, and 23ohms at the inside. There’s nothing visually obvious – do these sound reasonable or should I be looking elsewhere (‘stat?), or . . .
    Why do we always start these jobs too late at night??!! Many thanks for any assistance.
    #226879
    Stat or commutator switch if you have resistance across the elements are the most likely candidates unless there’s an overheat stat there that’s blown.
    HTH
    BunchofKeys
    Thanks for that, K – sorry to be dense, but what should I expect from my meter if testing the ‘stat? (I’m used to dealing with music gear, but cookers are virgin territory!)
    #226881
    Re: Misbehaving Caple 5210/1 top oven
    Oven thermostat is a make and break switch, so either zero ohms or infinite, depending on whether switch is open or closed.
    BunchofKeys
    Great, Penguin (I see you’re from my homeland, even better . . .) – thanks for the assistance. I’ll let you know!
    #226883
    BunchofKeys wrote:homeland
    Rodina……….
    :p45:
    #226884
    BunchofKeys
    Turned out to be an overheat thermal cutout thingy . . . thanks for all the advice. Kudos to all involved in the site – it’s great to have access to yer pooled wisdom!
