Mistral Mystery
  • #19282
    andy2
    Model FF92P
    Pretty much given up on this one! Usual problem, warm fridge. Reason – fan not running. No error codes, the door switch is OK and the fan runs OK on the test sequence which eliminates the motor, wiring and control electronics. Checked the fridge thermistor and it seemed OK registering temperature change on the display but replaced it anyway out of desperation but no difference. The freezer is fine at -22 and seems to defrost OK.
    The only thing that i can think of is that the module is not registering a door closed situation even though the switch is OK and the light goes off ie. the electronics do not sense the closed switch.
    Mmmmmm!
    #182531
    Simon46
    Re: Mistral Mystery
    Had an 8596 do similar. Fan not running thermistor replaced. The usual easy repair i thought. was still there 2 hrs later. Froze thermistor using pipe freezer spray saw Evap fan kick once for a second. Cust wrote it off.
    There isnt a batch of faulty thermistors going about is there?
    S.
    #182532
    Dave_Conway
    Re: Mistral Mystery
    andy2 wrote: Reason – fan not running.
    Evaporator thermistor Andy – 2601683 🙂
    #182533
    Simon46
    Re: Mistral Mystery
    Ah should learn to read properly 😳
    s.
    #182534
    andy2
    Re: Mistral Mystery
    All the thermistors seem OK and respond to temp change. Also defrost cycle is OK would’nt the evap therm affect defrosting?
    What makes you say it is this Dave please?
    Andy
    #182535
    Dave_Conway
    Re: Mistral Mystery
    The evap thermistor turns the fan on when the evap reaches -10C (I think the temp is correct), it’s a very common failure 🙂
    #182536
    andy2
    Re: Mistral Mystery
    OK thanks – its -6 deg according to the manual but i have a thermistor so i will give it a whizz nothing to lose.
    Andy
    #182537
    andy2
    Re: Mistral Mystery
    I fitted a new thermistor five days ago and it seems OK. Thanks very much for that Dave, much appreciated 😀
    I still don’t know why it was still defrosting OK though, every other faulty evap thermistor i have come across affected the defrost and blocked the evaporator. Which is why i discounted the possiblity.
    Maybe it is possible for only part of the temperature range to be affected on a thermistor?
    Andy 😀
