mmmmmmmhhhhhh very relaxing but still broke
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries mmmmmmmhhhhhh very relaxing but still broke
  • #51076
    Troffy
    hi everyone iv’e got a zanussi ZWF1007 thats humming when you turn it on then after about 5 seconds it goes to end program and stops, the customer said she heard a crack and ever since thats all its done, iv’e given the machine a full test and everything seems ok, i’m now wondering if it could be the board, i cant think of anything else, any help would be good
    Ian
    #306834
    Re: mmmmmmmhhhhhh very relaxing but still broke
    When you say a full test do you mean running the diagnostics program?
    Full Pnc number is always worth posting as well. 😉
    #306835
    whats humming?
    #306836
    Troffy
    hiya, iv’e tested everything with my kit, insulation and continuity, cant find a problem with anything in the machine, the humming sound starts as soon as you select a program and press start then 5 seconds later machine goes dead, the sound is coming from the motor, it sounds like its stuck but when you test it it seems ok
    #306837
    lee8
    Try turning the water on.
    #306838
    Troffy wrote:hi everyone iv’e got a zanussi ZWF1007 thats humming when you turn it on then after about 5 seconds it goes to end program and stops
    When the microprocessor detects an error it stops after 4 seconds in fact. At that point the start/pause button flashes intermittently red then green. Count how many times it flashes red and then how many green? That gives you the 2 digit error code and we can go from there if you like? 😉
    #306839
    lee8 wrote:Try turning the water on.
    If it was that it would hum for longer, wouldn’t it?
    Mike.
    #306840
    lee8
    They usually default into fault mode.
    And I had maybe too much wine when I wrote it. 😥
    #306841
    Troffy
    Hi Guys sorry about the delay, just got back off my honeymoon, the only flashing light is a red one, if flashes 4 times after the humming noise stops, then the machine goes dead 😕
    #306842
    keithwilliams
    just been to a mates tricity bendix aw1202w today.
    whatever you select on his, the drain pump runs for a few seconds then the end light briefly is lit then it goes dead. i noticed that the door lock does NOT lock.
    i’ve tried a new lock, tested heater for o/c and low resistance (o.k.) i’ve also replaced the thermister and checked the carbons and tacho.
    i took out the board and found no damage visible.
    now i’m stumped.
    hope some of this helps, and of course any advice for me would be much appreciated.
    keith
