Home › Forums › General Trade Forum › Mobile phones.
- This topic has 11 replies, 8 voices, and was last updated 19 years, 7 months ago by
ChrisR.
August 14, 2006 at 9:59 pm #19937
ChrisR
ParticipantI`m in the process of upgrading my mobile.Its a Nokia 8120? and has been very good and reliable.
I need a phone that can record a call whilst I`m driving via a handsfree kit,the Nokia does it perfectly by pressing two buttons….no problem.
I`ve used a Nokia 6680 but it wont record messages easily whist driving,you need to press half a dozen buttons which is no good when you`re trying to drive as well.
So over to you guys,what is best on the market that will record easily?.
Thanks.
August 15, 2006 at 8:49 am #185066macmini
ParticipantRe: Mobile phones.
I’ve got a Sony Ericsson K750i, it’s about 12months old now, but has 2mp camera etc, it can record in 3 button presses!
(More: Joystick Up: Select)
August 15, 2006 at 10:29 am #185067iadom
ModeratorRe: Mobile phones.
macmini wrote:: Joystick Up:
Seeing a Gegsy has passed on this one, I’ll do it. ooeerr Matron. 😆
August 15, 2006 at 12:42 pm #185068macmini
disgusting behaviour, you should be ashamed. :rolls:
August 18, 2006 at 10:46 am #185069robdray
Either of these any good ? Both have cameras & one has a vibrate function …
August 18, 2006 at 7:41 pm #185070macmini
wow, a 4.1MP Nokia 5110! 8)
August 19, 2006 at 8:31 am #185071EFS
Mines a Nokia 6020 I just press one button on the side to record on the move.
Steve
August 20, 2006 at 12:13 pm #185072ChrisR
Thanks guys for the replys.
August 20, 2006 at 3:16 pm #185073agro
Participanti hav a t-mobile mda on contract it does it with 1 press!!! s.
September 5, 2006 at 6:14 pm #185074washtec
dont get rid of your 6680, its the best phone in the world.
I cant seem to attach the program, but email me if you would like me to send it to you.try this program below.
Spy Call v1.2- Automated Conversation Recording Utility by Killer Mobile
Ultimate Ergonomic SeriesSpy Call is an automated conversation recording program designed for the Nokia Series 60 platform*. Spy Call detects all incoming/outgoing calls and automatically prompts you to save the conversation or not. Spy Call offers one touch recording, and requires no sound recorder program launching from the menu, no long keypress, no unnecessary effort. Spy Call is the most ergonomic application of its kind!
Spy Call – Knows the moment when you need it! Do you?
Feature list of Spy Call:
Record and save conversation from incoming/outgoing calls
Detailed information about the saved clip (caller name/number, time, duration, etc.)
Ability to playback clips locally
Support of AMR and WAV audio file formats **
Send the saved clips via Infrared/Bluetooth/Multimedia
Automatic startup on phone power on- MMC support
Note: Spy Call was fully tested on 7650/3560 and 6600 mobile phones. It should work on other Series 60 devices. Please test to verify that the program works properly on your mobile device prior to purchasing.
** – WAV files are more suitable when you want to transfer the saved clip to a PC, since you do not have to install third party Players to play AMR audio files. WAV files are native to the Microsoft Widows operating system. WAV files are saved using IMA-ADPCM compression, the file size is 3 times higher than AMR fiels on average, however they do have better overall sound quality.
Requirements: Installation requires about 50 Kb of the free space on the device. Nokia 6600 Users only – Special Notice: If Startup Mode is set to Automatic there is a chance that your calendar entries may get deleted. To avoid this simply switch the startup mode to Manual under the Settings option. A permanant fix for this will be available shortly. This bug only affects Nokia 6600 users.
September 7, 2006 at 1:25 pm #185075robdray
Nokia 6680 can record with one button push … you just have to change the task of either the left or right hand buttons under the screen … change one to recorder and just push it to get to the record function …
September 7, 2006 at 10:34 pm #185076cornwell40
I’ve got the K750i to record with one nudge of the joystick 😳 as long as the keylock is off!!
Tony C
