Model DWI 67.1 – Error code E1
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Model DWI 67.1 – Error code E1
  • #7151
    Just experienced error E1. Seems like the water intake is not happening. The model has Aquastop if that makes any difference & is approx 2 years old, used daily. Any advice out there ?
    Rob
    #121689
    Faulty Smeg Dishwasher Model DWI 67.1 – Error code E1
    Forget to state it was a Smeg
    Rob
    #121690
    Dave_Conway
    Re: Model DWI 67.1 – Error code E1
    E1 means the aquastop has activated.
    Most likely a leak and the base has water in it.
    If you need help with an engineer, pop your postcode up as someone here should be able to help, if you’re gonna have a go yourself, make sure you pull the plug 1st !!
    #121691
    ME7
