Model Electrolux ESL5201LO 91153913902 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Model Electrolux ESL5201LO 91153913902 Dishwasher
  • #96740
    DWSERV
    Went to see the two year old dishwasher complaint not heating on wash (Not seen this design before) Checked the usual check sump, confirm not heating then check for heat pump continuity no problems there. Visual inspect the PCB PB300 at the rear nothing…This time I select 30min quick wash and the dam thing heats but put it back to any other cycle and no heat. anybody seen this before ?
    #464655
    mikehha
    did you get it sorted got one doing the same thing
    #464656
    Hollytree_Technical
    I just today had a similar machine doing the same thing, turned out to be a faulty tacho on the motor, apparently if it can’t sense the motor speed it will run the motor to full speed and disable the heater.
    Jem
