Module for FFP187BP – Hotpoint F/F. no power at comp.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Module for FFP187BP – Hotpoint F/F. no power at comp.
  • #48130
    neon_3SP_glow
    Firstly Hi,
    I viewed a post with regards to a Hotpoint F/F (FFP187BP). The machine has no power to the compresser, as discussed in the post the m/c needs a module.
    It was pointed out that there are two different modules for this m/c (that look identical) and that a serial number would be needed to decide which one is needed.
    709210069 was the only other number I could find.
    Trouble is, when ordering from connect-distribution, it lists two modules (which differ in price) but has no info relating to which module is for which s.n.
    Does anyone have any info on this?
    #295674
    Re: Module for FFP187BP – Hotpoint F/F. no power at comp.
    Sent you some stuff.
    neon_3SP_glow
    I ended up ordering direct from hotpoint, phone call was very helpful and a lot cheaper that anywhere else i could find (not the phone call – the module :P)
    Fitting was easy, two plastic covers hiding two screws, top panel slides forward. Job done.
    #295676
    machineman
    Whats the difference bettween the two modules available for this model
    and how do you tell the right one
    connections just lists C00264544 and C00259773
    Thanks Dave
