Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › module for vtd60g
- This topic has 22 replies, 4 voices, and was last updated 16 years, 2 months ago by
bmrenr.
January 13, 2010 at 9:00 am #51582
bmrenr
ParticipantHi guys I am looking for a module for the above dryer could someone give me partfinders contact info please.
Tom
January 13, 2010 at 10:57 am #308603iadom
ModeratorRe: module for vtd60g
The part number is Here in your previous thread. 😉
Partfinder is a parts identification DVD, as far as I know you cannot contact it directly. 😀
February 2, 2010 at 3:40 pm #308604bmrenr
ParticipantRe: module for vtd60g
Hi I ended up getting both pcbs and now im getting f12 error code on the uk whitegoods error code book it says this is no communicartion between the boards for wash m/c is it the same for dryer. I have squeezed the connectors and even put a new set on . Is there some procedure I should follow when fitting new display and module?
Tom
February 2, 2010 at 4:19 pm #308605iadom
F12 is a comms error.
Check connector J9 on module;
• Check wiring between module connector J9 and display;
• Check display connector;
Jim.February 2, 2010 at 6:49 pm #308606bmrenr
I have done all of these checks. All seem ok. any other ideas.
tom
February 2, 2010 at 7:18 pm #308607iadom
Not come across this problem myself, thats all the service manual has to offer, sorry. :con:
February 2, 2010 at 8:48 pm #308608bmrenr
ok jim ,thanks for your help. well appreciated
tom
February 2, 2010 at 8:50 pm #308609helo_75
Participantplease tell me u programmed it?
February 2, 2010 at 10:22 pm #308610iadom
😳 DOH, I wasn’t looking for a base mounted PCB and in my haste missed the smartcard/card reader guff on Partfinder.
Its my age you know. 😥
Might be worth sticking the old console PCB back in to see if it was just the display that was faulty.
February 2, 2010 at 10:26 pm #308611eastlmark
really looking forward to seeing one of these, how many eeprom/module combinations are there……..
February 2, 2010 at 10:36 pm #308612iadom
Confused now, bmrenr, did you fit a new facia PCB or the main one in the base?
The one in the base has at least five different eeproms or five smartcards and three different modules. 😥
February 2, 2010 at 10:49 pm #308613helo_75
Participantoh the joy….
send it to emw, its the only hope
February 3, 2010 at 1:40 am #308614bmrenr
Hi I have fitted both display pcb and base mounted module.I ordered the base mounted module first and fitted it and it did not work so I ordered the display pcb.This is what happens I plug in the m/c and the display flickers for a second and just dies but when I keep the on button pressed f12 appears on the display and the clean filter neon lights up.I have put back on the old base mounted module but the same thing happens . I have not programmed the new module but when the old module is giving the same code is there any need to?
Tom.
February 3, 2010 at 10:14 am #308615iadom
All new modules need to be programmed with smart card and reader.
As there are three different base PCB’s how did you identify the correct one?
February 3, 2010 at 11:34 am #308616bmrenr
I just rang my supplier and gave him the model and s/n of the m/c. I thought the modules came pre programmed. I have heard of these smart cards and readers are they expensive and do you have to get a new one for every module?
Cheers Tom.
