module for vtd60g
Viewing 8 posts - 16 through 23 (of 23 total)
  • #308617
    Re: module for vtd60g
    Smart card is a one use only item, usually between £10 and £12.
    Card reader is officially priced at just over £88 ex vat. 😯
    Part number of card reader is C00252539.
    Thats why the EMW route is the best way to go. 😉
    #308618
    bmrenr
    Cheers Jim already ordered one from my supplier but should the old base module work as it was already programmed.
    Tom
    #308619
    If the fault was just bad connections or a faulty display unit it should. You could always send it to EMW to test and if it is OK you will then have a spare.
    Not had any instances of the LCD display going wrong on dryers but have seen one or two on the washers.
    #308620
    VENTED Drier for heavens sake! Timer, motor, heater, Belt!
    sorry!
    #308621
    bmrenr
    Hi I have just recieved my smart card and reader and followed the user instructions I have inserted the card and reader into the slot provided and connected to the mains but all I am getting is a red light and not green. Should I power on the m/c ?
    Tom.
    #308622
    Never used one personally, just too expensive when EMW/QER are out there.
    Hopefully this bump will get you an answer from someone who has used one.
    bmrenr
    Hi my supplier had sent me the wrong module and thats why I couldn programme the module . I have since recieved the right module and programmed it but all that happens is when I press the on/off button ON appears in the the display screen and when I select a drying cycle all I get is three beeps when I press the start button. Does anybody have any ideas as to what is wrong now?
    Tom.
    #308624
    bmrenr
    Anyone
    Tom.
