Moffatt 3000 built in gas oven: Seals for
Home Forums Public Support Forums Spare Parts Help Moffatt 3000 built in gas oven: Seals for
  • #11544
    Where can I get new door seals for a Moffatt 3000 gas oven, also I need a new doorcatch spring for the same appliance?
    #145728
    Dave_Conway
    Re: Moffatt 3000 built in gas oven: Seals for
    There’s a few versions of this one Linda.
    On the rating plate which should be around the door, can you post the GC????? number please.
    #145729
    I cannot find any numbers either on or around the door. The only other information I can give is that it dates from 1981/2, it is a built – in combined oven and grill unit with a glass drop down eye level grill door and the oven door (also glass), hinges on the left hand side. It has a mechanical oven clock, a minute minder and automatic controls. It is 1200 mm high. The User’s Manual states that when requesting spares or service the appliance should be referred to by its name, “Moffat 3000 Oven and Grill Unit. Unfortunately and unhelpfully, this manual does not provide any reference or part numbers, or even a list of available parts!
    In the absence of any identifying numbers, I hope that this helps.
    Linda
    #145730
    Dave_Conway
    OK, I’ve checked the standard 3000 model.
    These are the door seals that you “bend” to fit to the oven door I think with small tabs at each end and there are three in total ??
    Side seals 004289 at £3.50 each.
    Top seal 004288 at £3.50 also.
    Postage £3.95.
    Door catch is now obsolete though 🙁
    I can order for you, an email to spares@ukwhitegoods.co.uk please 🙂
    #145731
    Neville
    I am also seeking door seals for a Moffat 3000 built-in oven and grill unit. I have the original ‘Fitters Instructions’, which states that the appliance is GC Number 11-477-03 and that there are 3 oven door seals, GC Part Number 009 299, Makers Number 001/9584.
    Nev.
    #145732
    Dave_Conway
    It’s the same seals as above Neville 🙂
    Same email address as well if you would like a set ordered.
