Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › moms freezer
- This topic has 7 replies, 3 voices, and was last updated 20 years, 7 months ago by
admin.
August 24, 2005 at 1:08 pm #11541
KeymasterMy mothers freezer,(Fridgidaire EKC/084)has stopped working.
On inspection I have found a part which I believe may be called the relay (it has all the electrical connectors on it and plugs into the motor) has melted at the top and it smells quite offensive.
Would replacing this part solve the problem or should I be looking at why it blew in the first place?
Any advice would be much appreciated.
Cheers RayAugust 24, 2005 at 1:39 pm #145716Martin
ParticipantRe: moms freezer
A replacement Relay is well worth obtaining as it may be that it either died of old age or (if it has a water tray on top of the compressor) water could have leaked down onto it and caused it to expire ❓
August 24, 2005 at 2:31 pm #145717Dave_Conway
I can get the relay for you most likely Ray but that isn’t a Frigidaire model number, it’s more like a Whirlpool one.
Can you double check please and also the make/type on the compressor (motor).
Thanks.
August 24, 2005 at 3:07 pm #145718admin
KeymasterRe: moms freezer
Thanks guys I will see if I can get more info to ensure the right part.
Cheers RayAugust 25, 2005 at 9:52 am #145719admin
I have a little more info to help with identification.
Taken from inside the freezer….Frigidaire Elite…Type ZOS 210….Model FVE 2192. and finally on the motor which the relay plugs into FR7.5A……..-10282/0-7….
Hope this means more to you than it does to me.
Cheers RayAugust 25, 2005 at 11:49 am #145720Dave_Conway
Ah, that’s easy then, it’s a Danfoss compressor and not an uncommon occurance 🙂
There should be a number on the start device (relay), something like 103N0015 if you can read it ??
August 26, 2005 at 6:41 pm #145721admin
Well done Dave….it says Danfoss on the back but there is no number maybe because the top half has burnt.
Where do I go from here?
RayAugust 26, 2005 at 8:28 pm #145722Dave_Conway
I thought perhaps it may have burnt the numbers off, are you able to take a photo of the side where all the leads connect and email it to me please ?
These are fairly universal I just want to make sure the connections are the same 🙂
