MFF170W only just over 2 years old, Fridge compartment is freezing everything, Have defrosted and cleaned but no difference, Even when Temperature is set to below 0 which should switch fridge off it is still freezing everything, I have tested Bimetal Thermostat switch and the other Sensor switch in freezer area and both seem to be working, The only thing left that I can figure out is the PCB unit being faulty? Can anyone think of anything else that I should check or is there anyway of checking the PCB? Thanks for any help. Is hard to get any info of Google as most people just say to defrost F/Freezer and clean coils.
