Motor speeds up and slows down on spin Candy 1682D
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Motor speeds up and slows down on spin Candy 1682D
  • #83679
    laurenceuk
    The fault on this Candy is causing the motor to speed up then slow down continuously in spin. The relay on the control pcb can be heard opening and closing in sync with the pulsating speed.
    Is this likely to be the control board?
    What is the function the Rectifier PCB, mounted on the opposite side to the main control pcb.
    Thanks.
    Laurence
    #423421
    HotDog
    Re: Motor speeds up and slows down on spin Candy 1682D
    The heater can cause spin problems
    #423422
    laurenceuk
    Thanks HotDog, will give that a try.
    Laurence
