Home › Forums › General Trade Forum › motor temperatures
- This topic has 16 replies, 6 voices, and was last updated 16 years, 9 months ago by
simonb.
July 10, 2009 at 11:24 am #46953
simonb
Participantcould someone tell me as its been bugging me for a while now regarding motor temperatures, along side my repair business iv been refurbishing washers and always ensure each one is safe and sound, i always test with heavy load and if motor is red hot ill change it, what about quiet warm? the amount of times im doing away with motors that perform well under test but feel hotish always staying on side of caution, anyone know the correct working temperature of brush motors?
July 10, 2009 at 12:32 pm #291615leavemetogetonwithit
ParticipantRe: motor temperatures
Most, if not all, of them have a self resetting toc buried in the coils. I’ve often noticed motors getting a bit hot (enough to make you take your hand away quick) but never worried overly as long as they’ve got a toc. Also the house rccb, where present, should act before it got critical.
Several times I’ve replaced toc’s which have gone open circuit presumably following sevral trip/self-reset cycles. You can get them as spares for some motors. Never had a subsequent call to say machine has caught fire! Hope I’m not inviting disaster.
Mike.July 10, 2009 at 4:15 pm #291616simonb
Cheers mike, iv noticed a lot of hotpoint fhp motors seem to be running hot, take today changed it twice in workshop same thing still running hotish, your reply quiet reassuring i agree with toc although i always thought 1 shot, thanks simonb
July 13, 2009 at 9:41 am #291617Gazman1000
I don’t think there’s much to worry about with motors running hot, the TOC will deal with any problems.
The acid test is to mesure the current being drawn, under a known load, if it’s high the motor will get hot, it depends on load. Make up a socket with a test meter in circuit to monitor the machine in the workshop if you really want to test it.July 13, 2009 at 5:38 pm #291618leavemetogetonwithit
Gazman1000 wrote: Make up a socket with a test meter in circuit
Or you could use one of the now easily available and cheap plug in energy monitors as mentioned on another thread.
Mike.July 14, 2009 at 10:43 am #291619lee8
Just to put a spanner in the works.
Current Reg`s stipulate that certain safety checks should be made to all appliances before and after any electrical work is carried out.
These include the installation and the appliance.
The appliance tests will test the insulation of the componants within the appliance as ensure they are within safe standards.
Motor temp TOC are accurate to lots of zero`s, so no concerns there.
Although a few “mates” around do tend to bypass the TOC to get the perfectly good motor to work. 😥
It`s amazing though how many motors fail and require repplacing when all you went for was a door seal replacement. 😆
July 14, 2009 at 12:30 pm #291620leavemetogetonwithit
lee8 wrote:
It`s amazing though how many motors fail and require repplacing when all you went for was a door seal replacement. 😆Sometimes they just need taking off and giving a good clean to get the excess carbon dust out.
Mike.July 27, 2009 at 6:30 pm #291621suedehead1
hi i was at a zanussi fj1454w machine which i had changed the carbons a couple of weeks ago and the otor seems to be very hot with a hot “burning smell coming off it but it is still working ok.
is this ok?July 27, 2009 at 8:08 pm #291622leavemetogetonwithit
You have to be careful. Especially after what Lee8 said about some of his “mates”. 😉
Mike.July 27, 2009 at 9:35 pm #291623LJDomestics
It isn’t happy and wouldn’t think its gonna last.
July 28, 2009 at 7:50 am #291624lee8
leavemetogetonwithit wrote:You have to be careful. Especially after what Lee8 said about some of his “mates”. 😉
Mike.There not my mates, I was refering to the clients mates.
I don`t have any friends. 😥
July 28, 2009 at 11:20 pm #291625leavemetogetonwithit
lee8 wrote: I was refering to the clients mates.
“Melhor sozhino que mal acompanhado” It’s better to be alone than in the company of the wrong sort. 😉
Mike.July 29, 2009 at 7:56 am #291626lee8
lee8 wrote:
I was refering to the clients mates.I don`t have any friends. 😥
Mike.Creo que es mejor trabajar dentro de mà mismo.
En Espana es mejor, la trabajadores son una pequeña molestia.
Ustedes han trabajado en Portugal ?
July 29, 2009 at 3:59 pm #291627leavemetogetonwithit
Trabalhei como um professor inglês em Portugal há muitos anos.
Você fez máquinas laváveis na Espanha?
O que é inconveniente sobre os funcionários espanhóis?
(These online translation services are fantastic! 😳 )
Mike.July 29, 2009 at 4:23 pm #291628lee8
Mike.Not really.
I worked Spain for a few years and returned in 07.
Spent most of the time in Puerto Banus and Marbella servicing the Guiri`s.
Beyond Usted Cuel es la problema con la lavadora, senora, I need help.
Good experience in a strange culture. 😆
