Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Mould build up on door seal & water not heating up ?
- This topic has 6 replies, 3 voices, and was last updated 17 years, 1 month ago by
ecurran.
February 16, 2009 at 8:36 pm #43524
ecurran
ParticipantHi all
I have a Zanussi ESSENTIAL ( 6kg ) washing machine which is 1 year old & has major mould problem on the door seal.
I have read the articles regarding the reasons for the build up of mould on the washing machine doors & have started the cleaning process using, soda, vinegar & hot washes once a month with no clothes in the machine.
One thing I noticed today, I did a 95 degree cotton wash with no clothes, whilst the machine was emptying the used water I put my had to the water & it was cold ?? Not luke warm, but cold. Is the machine not heating up the water ? Could this be the major reason for the mould build up ?
Also is the machine faulty if it seems that the water isn’t being heated up ?
It is a cold only supply machine.Thank
ecurran
February 16, 2009 at 9:41 pm #277545helo_75
Participantmodel number might be helpful?
February 16, 2009 at 10:49 pm #277546cockney steve
ParticipantRe: Mould build up on door seal & water not heating up ?
If it’s SUPPOSED to be 95*, and it’s NOT, then sounds like you have a problem…..but bear in mind, that it’s only likely to be the WASH that’s heated and the rinses are all likely to be cold.
February 18, 2009 at 6:04 pm #277547ecurran
Sorry I haven’t responded earlier but have been away from computer a bit. I will post the model number when I get home.
Cockney Steve, when I checked the water coming out of the washing machine waste pipe the water was running thick & fast as if it was from the wash & before the spin ? The water around the spin time is not as fast, sometimes a trickle, but still cold.
Someone advised me that the glass door of the washing machine should be at least ” warm ” to the touch when a 95 degree wash is on ?
Thank you
ecurranFebruary 18, 2009 at 6:39 pm #277548cockney steve
Yes! a hot wash will warm the lass and you’d normally smell a “hot soapy water” sort of smell.
sounds like you need to check the heater…..(we are ASSUMING it’s out of warranty!…..CHECK!!! )
unplug machine, access heater, disconnect wire from one terminal, meter across terminals should give ~ 25 ohms…..meter one terminal to earth “should” be infinite…..if it’s not, disconnect the other wire and check again……the2 terminals should have resistance between them , but neither should go to earth.
lack of continuity (open circuit) =burnt out low resistance to earth = short-circuit.
TIP. use a digital camera as a “notebook” as you strip stuff and BEFORE you remove any wires.
The above assumes your machine has a simple, single element….if there’s a compound element, there will be a “daisy-chain” wire linking all the “common” sides together. test each one by isolating, as above.
Meanwhile, I’m not a professional repairer,so exercise due caution and use what i say as guidance, not gospel 😆
February 18, 2009 at 7:35 pm #277549helo_75
Participanterm, if your checking the water before a spin, itll have been on a rinse
February 18, 2009 at 9:46 pm #277550cockney steve
DUH! 😳 ….well, I DID say “i’m not a professional” 😆
