Fault Code 9
Size Setting error
Have to reset Size Setting
Press & Hold water temp up button then press to enter Size Setting mode
To Set Size for 5Kg (Yours) press Wash temp up Button Then Power to Store
Ok when you say pump wont turn off are you referring to water supply into machine (Inlet Valves) ?
Turn Water supply off to cold Then hot Tap To see if both or one valve is the problem here
If the power is off the Pump (Drain Pump) cannot Work
Fault Code 48 is a Water valve Fault
Could be Faulty Water inlet valve or Motor Controller (Main PCB)
