MW059 size resetting
  • #11012
    Hi Alexa, i have a MW059NZ smart drive 9 washer, which the control module has gone. i took a same module from another machine(GW509) and put into MW059, but machine just keeps beeping with LEDs pattern 00001001. this should mean “size switch” error so i tried to reset the size by “press and hold PAUSE/START, then press POWER on, then turn POWER off”. But this doesn’t work! i’ve checked with part supplier, they said those two models do use the same “control board”. can i get help on how to do “size reset” for this machine? thanks a lot.
    #143609
    Re: MW059 size resetting
    Press and hold wash temp up and then press power. Release and press wash temp down, The cold light only should be on. Press power to store.
    #143610
    thank you very much Kiwi !! just wondering why the instructions in the manual do not work? maybe different ways for different models?
    #143611
    Short answer: YES. 🙂
