mw511 error code 00101011
  • #43937
    kenjikool
    Sorry posted this twice I think I’m in the right area now?
    Anyway, the pump works fine but the water is not pumping out. there are no blockages i can blow through the pipe.
    Any help would be great, Thanks
    #279142
    bigsmokepiker
    Re: mw511 error code 00101011
    Fault code 43
    OOB switch error
    CHeck Bowl Is Balanced Check Bias Spring is keeing bowl central
    Most Likely Cause Corred terminals on Out Of balnce microswitch
    Numerous Threads on This Isssue
    Checking for blockages by blowing thru drain Hose Doesnt mean Theres Nothing Blocked Or Twiste around The impellor of The Pump
    #279143
    kenjikool
    Thanks for the reply. I took the pump off and checked for blockages previously, and took the hose off to empty the bowl. I ran the pump by itself detached and it is working fine. The machine will spin no problem also with a small amount of water or wet towles but still will not pump out the water. Basically the machine does everything its suppose to wexcept for some reason no water comes out!
    Is there a valve somewhere along the hose that my not be opening?
    Thanks.
    #279144
    kenjikool
    Oh also, i am assuming that the error code must be from a previous event when it was unbalanced? Because it seems to be a problem with water not pumping out even though the pump seems fine, not a spin/balance problem….
    Thanks.
