MW511 Error on power up (00110001)
Home Forums Public Support Forums International Forums Australasian Appliance Forum MW511 Error on power up (00110001)
  • #26796
    Planky
    During a wash cycle, my F&P stopped and started beeping, it also displayed the following code:
    0 0 1 1 0 0 0 1 (49)
    From what I have read in other threads about this – the cold water solenoid is faulty. I have swapped the hot and cold water – but cannot start the machine (each button just causes a beep, hitting start turns the lidlock light on which flickers).
    The machine is under warranty, so I am not overly concerned, but I would like to know whats going on with it.
    #211410
    Re: MW511 Error on power up (00110001)
    Yup, 49 is cold water valve. Coil may be open circuit (should be 64ohms) or not getting volts (up to 24vdc). Wiring harness often causes headaches. Presumably the self diagnostic routine on start up is preventing the machine from starting, due to fault detected.
    Let us know how it works out,
    Planky
    Cold water solenoid died, which in turn took out the control board (the Solenoid earthed itself and shorted). Both replaced and now working.
    #211412
    Planky
    That didn’t last long. Machine is giving the same error code again. Hopefully it hasn’t killed the control board this time round.
    Pretty odd it died not 4 days later after being replaced.
    #211413
    You should have fitted valve p/no 420147?
    GML
    Thanks for the tips on error 49.
    I replaced the solenoid but still had binary 49 LED code. I chased the circuit through the Motor Controller (brown one in Australia) GW712.
    It was a couple of FETS or Qs in a H drive. The get fed their +v from the main power rectifier. There is a funny looking round component called F^ which is a quick blow 1.6 A fuse. Because my solenoid had a shorted turn on it (bubling to outside packaging) it had blown this.
    I didn’t have one instock so I substituted an ordinary glass 2AG 2.0amp fast blow. You need to remove the old fuse and solder 2 wires into the holes left these are inturn soldered to the fuse ends. I used hot glue to hold the fuse clear of any other components.
    You can get slow blow fuses almost anywhere. In my experience ordinary fuses are the same they always fail after the components are lost anyhow!
    If you are desperately dirty you could just jump the 2 holes with tinned copper but this could represent a fire hazard if a solenoid goes again.
    We amke microcontrollers. It is a simple fix and saved me $350. A fuse is 10c or maybe $1 if you buy them one at a time. Make sure you test the plugs before you start up. My GW712 read:
    1. Each motor winding ~ 35 ohms to any other
    2. The lid solenoid ~ 70 ohms
    3. Each water solenoid ~ 60 ohms
    4.The thermistor ~ 10K ohms
    # When this fault exists you can empty the water by removing the tube to the Pressure Xducer and using a tube from your mouth to blow into it HARD!!! The pump will start and pump it out for you.
    To calculate the error code (for what use that is when you can find out)
    LEDS indicating wash cycle
    X X X X X X X X
    128 64 32 16 8 4 2 1
    Add the values for each light LED
    #211415
    Hotwire
    Hi all,
    I have an MW511 and get the above error code. I checked the impedance of the solenoid, and its reading 62 ohms so obviously not the problem. I dont know if its getting 24V DC either as when I turn the machine on at the power point, it goes straight to beeping and giving me error code 49 – so it wont even attempt to fill etc, and I’m getting 0V at both solenoids..
    What else could I try? Dont really want to pay some serviceman $121 to tell me when its simple fault finding – I just need to know what to look for!
    Lee
    #211416
    fabnz
    GML wrote:Thanks for the tips on error 49.
    X X X X X X X X
    Great to find this forum & information as my MW511 (NZ) came up with the same error.
    Went to F&P parts here in Christchurch this afternoon. Brought new solenoids at $24.31 each. Had to fit old seals from original solenoids. Assy but blew new fuse.
    Inspected the Motor Controller (SD11) and found one MOSFETS that drive solenoid dead.
    Off tomorrow to buy
    2 Transistors – (N-Channel, 600V, 2A, DPACK)
    1 Fuse – (Micro 1amp Fast blow)
    Will post outcome
