Hi, we have a MW511 Fisher and paykel washer, a couple of weeks ago it started looping the cycle continuously. (ie, it would finish spin and then start the cycle again). After reading this forum I found the problem was that it was set on loop cycle. I reset it and all was well with the world.
Then it started doing it again. So I tried resetting it again, but it doesn’t work and all the lights flash when the machine is turned off. (Only the last 3 flash if the loop function is on). I’ve tried turning it off for a while to reset it but makes no difference.
Also, there are no error codes coming up. Any ideas?
Mike
