I have a Candy built in oven model FPE409/6X and it has just stopped working. There is power to the screen and I’m able to set the clock but when I try to turn it on nothing happens. The light on the front panel does not come on, the internal light doesn’t come on, the fan doesn’t come on and the oven doesn’t heat obviously. It did this last week and after turning the knobs on and off a few times it started working but has now stopped again. I’m 69 and really can’t afford to buy a new oven if I can help it so I’m hoping this might be something simple that I can sort myself. By the way it’s not the child lock function as the word stop does not appear on the clock.
when fit the switch, take photo’s before and do it one wire at a time
wont do any harm to take the top off and look at the switch and look for burning wires. if they are discoloured its better to change it before it destroys the wire connections
if it has you will have to cut the wores back to clean copper and fit new connectors
