My indesit IS70C dry wont produce any heat
Home Forums Public Support Forums Help And Support Washing Machine Help Forum My indesit IS70C dry wont produce any heat
  • #47084
    adyt
    Can anyone provide any info my indesit IS70C is working but won’t dry the clothes as no heat is being produced.
    Thanks in Advance for any help
    #292261
    helo_75
    check the thermostats over the heater, theyre in the back,behind the banjo shaped panel
    unless the empty water lights on of course….
    #292262
    Re: My indesit IS70C dry wont produce any heat
    As Helo says, thermostats, very common to fail.
    There’s two kists, you need to check the colour of the dots from memory, this one and this one that can fit.
    Don’t buy the cheapo Chinese copies, rubbish they are. 😉
    adyt
    Thanks for these quick replys guys, I’ll check out 2nite when home & let you know how get on
    thanks again
    #292264
    adyt
    Checked it out & it is the ones with white spot, i’ve ordered replacements as your link, let you know how get on when they arrive.
    Cheers
