My love affair with a HOTPOINT WD440 washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum My love affair with a HOTPOINT WD440 washing machine
  • #78648
    PARISS
    posting.php?mode=post&f=34#.Several years ago I had numerous problems with this machine, and I managed to fix them with the help of this site. My latest problem is all lights flashing, I have taken photos of the circuit board to identify the connecting wires to the board I then removed the circuit board .With help from the forum I replaced c17 a 680Micro Farad capacitor (which I think was working to check it I put 9v across it and it held its charge). I replaced the board and no lights flashing switched on the machine F 40degrees it worked for less than 5 mins and then it displayed a f10 problem . I also noticed that the dryer fan was on (read on?) this should not be the case. When this occurred I immediately switched the machine off.
    I checked the pressure switch and plastic tube both seem ok continuity and blew through the tube and heard a gurgeling sound so it must be clear. I notice that the circuit board has similar red and black loose cables one goes to the water heater element and the other I assume goes to the dryer element (photograph not much use similar connections and colour), I may have reversed these , looking at the board mounted in the machine are the wires connected to the water heater element , on the left or right hand side of the board. I will reverse them and see what happens. When I removed the board I checked the relays and they seem ok. Repairing this machine is a challenge . I will purchase a new machine in the new year. It would appear as if the board may be broken. Just one separate question why does the machine vibrate so much can this separate problem be solved the machine is level and the spring seem ok. Any suggestion on these problems would be welcome
    Happy Xmas
    #406424
    PARISS
    Re: My love affair with a HOTPOINT WD440 washing machine
    Sorry that should be red and blue loose wires.
