Mystery: Zanussi ZWC1300W
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Mystery: Zanussi ZWC1300W
  • #80326
    jgurney
    3 year old Zanussi ZWC1300W Compact.
    If I start any programme: water rushes into the drum for 30 seconds, but then dumps out immediately afterwards, prematurely ending, with the LED lighting “End” and flashing “Door” continuously.
    It is a dial control, not a digital control, and it doesn’t seem to be showing an error code.
    I have already made sure that:
    – the inflow pipe is clean and clear. It is not in an odd U-shape.
    – the outflow pipe is clean and clear. It is not in an odd U-shape.
    – water comes in and drains out just fine.
    – the filter is clean and clear.
    – the detergent tray is clear.
    – the drum’s motor works, i’ve put the machine into test mode and it spins just fine.
    – I’ve turned the machine off at the mains and let it rest.
    This problem came about when I tried to set up an 8 hour delay wash, although I don’t know why this would be relevant.
    Any help would be most appreciated, am not sure whether to buy new or can it be easily fixed…
    Joe
    #412451
    Re: Mystery: Zanussi ZWC1300W
    Check the heater for earth insulation leak 💡
