Re: Naff Oven Lamp Holder
well it might be
it pushes in the way and metal clips spring out to hold it. you should be able to bend those clips from inside the oven and withdraw it
poss bad news i dont know how long the cables are so once it is released you have to pull it through enough to disconnect and reconnect the new one
if you need to get it out best way is a black and decker workmate. then you have a secure surface to take the back off and change it and you dont have to lift it down to the floor. also there may not be enough cable on it to do this
