nardi dishwaher lsish or ls1sh
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries nardi dishwaher lsish or ls1sh
  • #47141
    got this dishwasher ls1sh or lsish 20035118245
    machine starts runs for about ten minutes on quick programme then stops full of water. you can hear a buzzing sound from the soleniod on the softner unit then nothing
    display is damaged think i was getting error codes beginning P poss P6 or P4 not easy to tell if i had list of error codes it would make life easier.
    customer has had another engineer out through her insurance who has condemned this timer but i think there may be another fault and it is only the timer display that is faulty. you can see some of the display but on the right number the top and bottom arms dont light up.
    Also the door does not shut properly think the hinges have been strained. door is ok till last inch then you have to push harder then i would like to close it. when you look at the hinges there is a metal panel that runs horizontally across the machine the the hinges contact before the door is fully shut. i also need the string that connects the door to the springs
    I know this may go on a bit but if anyone has any info or advice even if it is throw the load of ***t away i would be grateful
    thanks
    adv
    Re: nardi dishwaher lsish or ls1sh
    scrap yard mite get£3 😆
    #292448
    if i am lucky lol 😆
