Nardi EK98553AX Oven
  • #91107
    PaulNickG18
    I have the above oven, the following morning after I used it it didn’t work. There was no electrical power to the cooker. There was power to the main socket. If I switch it on at the socket nothing electrical works even the ignition for the gas burners. I have checked the terminal block and that is fine. Any ideas as to the problem and how to fix it and parts needed. Thanks!!
    #447082
    Re: Nardi EK98553AX Oven
    you are talking about an oven but then say you gas hob burner ignition does not work. since the oven and hob are not connected it has to be a power problem feeding both appliances
    remove the oven and trace the electrical connections
    PaulNickG18
    Thanks Dave. It is a dual fuel cooker. The top five burners are gas with a electric oven/grill. There is no power to the electric parts of the cooker. As I said even the ignition does not work.
    Paul
    #447084
    That makes more sense fooled me by describing it as an oven
    It’s got to be the power to the whole unit. Check the connector block. If there is power getting to the cooker some cookers have an overheat stat on the electric feed into the oven look for that
