Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Nardi electric oven EK95583AX tripping breaker
- This topic has 9 replies, 5 voices, and was last updated 20 years, 2 months ago by
MGA.
January 19, 2006 at 12:25 pm #14950
MGA
Participanthave just fitted new base element to this unit, just getting p/w signed off when tripped. Unit is tripping with no elements on either at top or bottom, just when t/stat is switched. would this now be the stat faulty or am I missing something here. thanks
January 19, 2006 at 1:48 pm #161440Dave_Conway
ParticipantRe: Nardi electric oven EK95583AX tripping breaker
The fan element ?
January 19, 2006 at 2:11 pm #161441MGA
No fan element. oven gets heat from grill element and base element only.
If you switch selector switch to oven light so there is power on, and then turn t/stat, then it trips. Neon was disconnected also.January 19, 2006 at 3:13 pm #161442Dave_Conway
That’s odd, on the spares diagram and parts list it shows three elements 😕
January 19, 2006 at 3:44 pm #161443woz
There’s a good chance the new element has damp ingress.
Try and run the oven on full with the earth disconnected to dry the element out.
If that not does the trick it could be one of the other elements is about to go try meggering them 👿
RCD’s 👿
woz
January 19, 2006 at 4:04 pm #161444MGA
thanks. will try the above. Fan element removed?? will ask customer if they require new. strange!
January 19, 2006 at 4:07 pm #161445MGA
Dave, would you be able to e-mail or fax me spares diagram and parts list please?
January 19, 2006 at 4:32 pm #161446Brains
MGA
If the elements test ok, check the cooker control unit on the wall & the cooker outlet plate (if fitted). I have had insulation problems with cheap makes.
Regards
January 19, 2006 at 4:45 pm #161447NWAR
ModeratorRe: Nardi electric oven EK95583AX tripping breaker
MGA wrote:Dave, would you be able to e-mail or fax me spares diagram and parts list please?
MGA, I’ve emailed you the diagram.
January 19, 2006 at 4:57 pm #161448MGA
Great, thanks very much.
much appreciated.
