Nardi Grill not working.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Nardi Grill not working.
  • #23113
    Perksy
    I’ve recently acquired a Nardi oven when moving into my new house. However, the grill element doesn’t work – can this be replaced?
    #197053
    Re: Nardi Grill not working.
    Of course it can be replaced. Now tell us the model number and we’ll try and work out what you need…….. 😀
    Perksy
    Its a Nardi EK95583AX – 90cm Oven.
    #197055
    Dave_Conway
    The grill element (assuming it has failed) is part number 040125009901R priced at £54.34 inc VAT and carriage 🙂
    An email to spares@ukwhitegoods.co.uk please if required.
    Power off when checking please :zap: or check the repairs@ link below for an engineer if you’re unsure.
    #197056
    Perksy
    Is there another reason why it might not be working?
    #197057
    wsts
    Perksy wrote:Is there another reason why it might not be working?
    Yes ….. it could be the energy regulator (switch).
    #197058
    Perksy
    How would I check if it’s that?
    #197059
    Dave_Conway
    The element needs to be tested for continuity with a meter unless there are obvious signs that is has failed.
    If you are unable to do this then you will need an engineer 🙂
