Nardi LVAS 1000 – pulsing water inlet valve?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Nardi LVAS 1000 – pulsing water inlet valve?
  • #99329
    Loz2212
    Hi guys,
    My washing machine has started to cycle the water inlet valve on and off every second… I can also see there are 2 water inlet valves but only 1 cold feed coming in – strange!
    What could cause this? I can see one of the wires from the inlet valve goes into the mechanical timer and the other goes down to a circuit board that is screwed to the casing at the bottom.
    There seems to be quite a few spares available on eBay so thought I’d give it a bash.
    Any help would be great – thanks.
    #475883
    Nardi ceased trading some years back and info on them is now non-existent so, hard to help really.
    It will be a branded unit, probably Ardo Merloni (Servis) but they also went bust in 2008 so no hope there either.
    As for parts, given the above, I’m sure you’ll appreciate there’s pretty much no hope now.
