Hi, can anyone help me with this one please?
machine starts cycle ok, empties dregs, but then fill valve doesn’t open.
Machine soon stops with the all 5 leds on, with the rh one flashing.
I’ve aslo checked:
Valve is ok -it fills if you give it a neutral.
Fill pressure sensor (on front rh) seems ok – pipe blows through – you can hear switch clicking over on blow- but Ive not tested continuity.
It seems that the empty might be taking too long, before stopping – does it have another level sensor that could have failed, and the program is timing out?
Any ideas much appreciated…
before I try ebay for a s/h Bosch!! 😉
Thanks, Harry, Huuddersfield
