Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Nardi oven
- This topic has 9 replies, 2 voices, and was last updated 20 years, 7 months ago by
iadom.
August 31, 2005 at 2:44 pm #11691
ModeratorCustomer just phoned with a Nardi oven, message on answerphone so don’t have a model number yet, sounds like an element fault. What is the spares availabilty like on these. She also has a fridge that needs a hinge but that has no name on it at all. 😥
August 31, 2005 at 3:54 pm #146269Dave_Conway
ParticipantRe: Nardi oven
I have most of the info here if you need any help with this 🙂
Model numbers are required though as most of it is rebadged Brandt/Merloni stuff 😕
August 31, 2005 at 3:59 pm #146270iadom
ModeratorRe: Nardi oven
Thanks, will give her a call and arrange a visit. :tup:
September 1, 2005 at 3:25 pm #146271iadom
Right. Oven is a Nardi FE0614 ( no other info available)
Oven element goosed.Integrated fridge is a Necht, only model info I can find is on salad bay plate. Model N2. no other serial number or info.
Requires bottom hinge.
This is one of those kitchens you dread. The fitted kitchen firm supplied all the appliances ( big mistake) the job cost her £6,000 just over 2 years ago. The hob extractor does not work, the Necht dishwaher has been written off after numerous service calls, the bulb in the fridge has burnt the inside of the liner etc.
September 1, 2005 at 4:14 pm #146272Dave_Conway
040199009932R is the fan element, available from Masterpart for about a tenner.
The hinge should be either 246009800 or 246009700 have you seen it yet ? have a look here:
http://shop.ukwhitegoods.co.uk/hingekit … -hinge-kit
Hopefully they are the one’s 🙂
September 1, 2005 at 4:23 pm #146273iadom
Thanks Dave, is there a Qualtex match for that element.
Not sure about the hinge unless one of them is as blue as that picture. I have seen it but it is difficult from that pic to decide which is which.
The one on the fridge is not that blue.
Nb. sussed the hinges, when I had worked out my right hand from my left I knew which I needed. 🙂
September 1, 2005 at 4:40 pm #146274Dave_Conway
Ignore the colour, it’s a cr@p photo 🙂
If it looks like them it will be almost certainly, one is top left/lower right and the other the opposite diagonal. If it turns out that it’s wrong, bring it to Sibson and I’ll buy it off you as I sell 100’s.
ELE2015 should fit the oven, it fits nearly all the NArdi one’s, now a 3 turn 2.5kw element (improvement apparently ;))
September 1, 2005 at 4:47 pm #146275iadom
Thanks again, I did eventually take the trouble to read the info 😳 and spotted the difference in the handedness of the hinges. Looks very much like the correct one. :tup:
Any idea of the AM120 hose ??? 🙂
September 1, 2005 at 4:51 pm #146276Dave_Conway
iadom wrote:Any idea of the AM120 hose ??? 🙂
:wave:
September 17, 2005 at 5:54 pm #146277iadom
HELP.. Fitted element ELE2015 to this cooker today. Fitted perfectly. Customer has just rung up to say that the inner glass door of the oven has exploded !!!!!
Could this be due to the new element or is it down to my usual bad luck. Is the inner glass door available for a Nardi FE 0614. Customer is one of those that is likely to demand a new cooker. 😥Still, I could always ask Dave to go halves, 😉 🙂
