Re: Nardi oven fault – will not heat up
Almost certainly the fan element will have failed. The back inner panel of the oven can be removed for inspection – cut the power first.
I have not been able to find any reference to your model number, so you may wish to double check that. An email to spares@ukwhitegoods.co.uk should source an element for you if required.
If you’re not sure how to proceed, click the link below for a UKW repairer in your area.
