Narrow width tumble dryer 560mm
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Narrow width tumble dryer 560mm
  • #18299
    squadge
    Hello,
    I need help finding a dryer with a decent capacity e.g. 6kg but at 560mm width or less. Everything I see is 600mm width or then half size. Does anyone know of a space saving model?
    Thanks,
    Squadge
    #178503
    Goatboy
    Re: Narrow width tumble dryer 560mm
    I don’t think one exists 🙁
    But if anyone knows, Don will :tup:
    While your at it Don, is there a shallow model too?
    #178504
    don
    I`m afraid not squadge all the larger models are 600 wide 🙁 . However Hotpoint, Creda amongst others produce a compact machine which measures 670 high 490 wide and 480 deep, however the load size is 3kg. On the bright side it`s better than nothing 😉
    GB :wave:
    Zanussi produce one TC180W slimdepth condenser dryer 686 high 595 wide 420 deep. Downside it`s only 3.4kg :wink:. Upside it can be wall mounted ( comes complete with kit ). Retail circa £299.00 🙄
    Don
    #178505
    Goatboy
    :wave:
    Cheers, anything in a vented?
    #178506
    don
    Nothing on the market that I know of GB. Perhaps it could be something in the future for ISE 💡 😉
    Don
    #178507
    Goatboy
    don wrote:Perhaps it could be something in the future for ISE 💡 😉
    No way! Nobody really needs a shallow dryer. Just another one of Goatboy’s unique customers 😉
    Thank you Don 😀
    #178508
    squadge
    don wrote:I`m afraid not squadge all the larger models are 600 wide 🙁 . However Hotpoint, Creda amongst others produce a compact machine which measures 670 high 490 wide and 480 deep, however the load size is 3kg. On the bright side it`s better than nothing 😉
    Ah well. OK if it has to be a small one how about recommendations for the best tidgy all rounder. 😀
    Cheers everyone.
    Squadge
    #178509
    don
    Hi squadge
    The Hotpoint/Creda machines are very much the same, these vent through the door or the White Knight which vents from the rear. These seem to be the best ones around. Go for a reverse action model to give a slightly better drying time and tangle free clothes at the end of the cycle, there`s hardly any difference in the price 😉
    Your`e local independant retailer will be able to help.
    Don
    #178510
    squadge
    Thanks Don and the rest of you white goods gurus. 😉
