Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › NEB ceramic hob cutting out
- This topic has 10 replies, 3 voices, and was last updated 20 years, 6 months ago by
pslaidler.
September 26, 2005 at 4:03 pm #12187
pslaidler
ParticipantHi guys,
I have an NEB Rimini hob (from B&Q) which I purchased just over 2 years ago. The power to the whole hob started cutting out occasionally about 6 months ago. Because it was an intermittent and short lived problem we put it down to dirty glass disrupting the touchpad or sensors. It became worse last week when the hob would only work for a few minutes before cutting power completely. We pinned it down to the front left ring and found that leaving it off meant the rest of the hob worked.
If we switch the oven on underneath then the hob refuses to work at all until the oven has cooled.
Does anybody know if replacing the ceramic element will probably solve the problem? I don’t know if any of the circuitry is hidden under under the touch pad sensors and don’t want to dig around too much. My understanding is that because the element has a thermal switch attached then that should be all that needs replacing but I just need confirmation that this thermal switch is capable of removing power to the whole hob rather than the single element?
Hob no is: NEB 15 RIMINI SSTC CER HOB 02 11 214099
Element is ceramaspeed 22-10-02 Model 200N3 l57120 1334 (1800w)Many thanks for your help, Phil.
September 26, 2005 at 5:43 pm #148277Dave_Conway
ParticipantRe: NEB ceramic hob cutting out
I don’t have access to a wiring diagram for this hob but it’s highly unlikely that the thermal switch on one element would shut the whole hob down.
Taking in to account the oven mentioned which appears to affect the hob, even though they have no internal connection, it may be an installation problem (poor mains connection) perhaps ?
Power off when checking please :zap:
September 26, 2005 at 7:57 pm #148278pslaidler
ParticipantThanks Dave,
Having taken the element out and had a look at it I can’t see how it would affect the whole unit either – there are only the power connectors attached to it and no other wiring although there do appear to be two positions to the switch. As the probe expands it triggers the first switch – which I assume is to control its heat – but if it continues to expand there is a further switch which I assume is the safety cut out.
It just seems strange that this ring is the only one that triggers the whole hob to shut down. The other 3 can be used without problem. I have checked all connections and they are fine. If the oven is used then it triggers the shut down once it has heated up so i assumed the heat from below was affecting the faulty probe.
Probably too many assumptions! I guess I need to get it seen to professionally.
Thanks for your help.September 28, 2005 at 8:26 am #148279pslaidler
Swapped the two large elements over last night but the problem persisted on the front left ring so obviously the element is not to blame after all.
Now I need to source a replacement control panel board as it is easily replaced with lug connections.
Thanks for your help Dave.
PhilSeptember 28, 2005 at 8:34 am #148280Dave_Conway
Part number is 4174556, would you like me to find out price/availabality for you ?
September 28, 2005 at 11:22 am #148281pslaidler
That would be great.
Still in a battle with B&Q over my 5 year parts guarantee not being honoured so I am expecting to have to do it myself anyway.September 29, 2005 at 12:07 pm #148282Dave_Conway
£143.21 inc VAT 😯
Available from Expert Appliance Care on 0870 9099100 but personally I’d buy a new hob 😉
September 29, 2005 at 12:44 pm #148283pslaidler
At that price I think I would too!
I am going to continue to battle with B&Q and hopefully they will cough up for the part.
Otherwise it may be a trip to trading standards.
I really appreciate it.
PhilSeptember 29, 2005 at 8:27 pm #148284pslaidler
Called expert appliance care re: the part and got hold of a lovely lady who was most helpful. I was told that as long as I had the guarantee and receipt then I should not be charged for the part. B&Q head office insist that guarantee is only for 1 year and that they will not pay for the part.
Decided to pay a visit to the store as I just had visions of the part being charged to my card along with the call out. I was offered a 20{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} discount on any new hob – which I thought fair as I was staff at the time I bought the Rimini and got a discount on that anyway. Have decided to buy a bog standard stainless steel electric hob – which now will not cost me any more than the callout charge would have and I will keep an eye out for a damaged NEB 15 that I can eventually poach the circuit board from.
Shame to lose my sleek ceramic hob but the hassle just isn’t worth it.
Anybody else get any joy from the B&Q 5 year parts guarantee?October 4, 2005 at 7:24 am #148285woz
Just a note B&Q NEVER offered a five year parts on the NEB range. This guarantee was only on the HOMARK range which B&Q dumped in favour of the NEB range. 👿
They decided to go it alone in the applaince world to buy and badge there own products. Look how long that lasted 😯
Personally i don’t think it is the board. I would defo say it’s an installation fault (ventilation). with the front large ring being so close to the PCB.
On the PCB is a Thermal switch which will activate if there is not enough ventilation beneath the hob (top rail of the cabinet should have been removed between oven and work surface).
Good look with the solid plate I give it about 2 weeks before the stainless steel turns gold in colour.
Hope the information helps and the guarantee part is very true
Regards
Woz
October 4, 2005 at 1:09 pm #148286pslaidler
Just seems strange then that I have the instruction book from the hob and it definitely says in the back 1 year labour, 5 years parts (just as others have said.) Trading standards agree that responsibility lies with B&Q and they should honour it.
Definitely not a ventilation problem as I had it installed in a stainless steel ‘range’ contraption which gives full ventilation and the problem plate is actually the furthest one away from the PCB.
Further inspection revealed that the big black box on the PCB was hissing and crackling when the hob was turned on which could be clearly heard before the thing finally died.
Managed to get a whirlpool s/steel hob for £40 in a clearance sale so that will do me until I can save up my pennies for a new ceramic hob – definitely not Nardi and definitely not from B&Q! -
