Home › Forums › Public Support Forums › Spare Parts Help › NEB Oven – Broken
- This topic has 4 replies, 3 voices, and was last updated 21 years, 6 months ago by
admin.
October 7, 2004 at 9:48 am #6429
KeymasterLooking for spares for NEB Oven. Have just moved in to a new house and cooker has gone on the blink. Two problems – first think the thermostat for the grill was defunct as the grill would not heat up properly. Then when trying to reset the time the whole digital display has cut out and now nothing on the oven works (there is power as power light blinks on briefly when I turn it on at the wall) won’t heat up and no display.
Any information appreciated – possibly looking for new controller and new thermostat. – Can’t seem to find any information about NEB or the manufacturers website.
MOD. VENEZIA SS
Mod. FE8622EXCOD. NEB01
Cod. A288October 7, 2004 at 10:19 am #117584Dave_Conway
ParticipantRe: NEB Oven – Broken
Hi Ian.
I would suggest you ask an engineer to check this out a it sounds suspiciously like a loose or poor connection somewhere to me.
Both of those faults are synonymous with the above 😉
October 7, 2004 at 10:24 am #117585woz
Hi Ian
To use the grill you have to turn the selector to grill function.
Turn the oven thermostat to max position then use the grill regulator to select the temp you require, silly i know but it’s a safety thing.
As for the Timer it could well be faulty.
Expert Appliance Care Ltd are the official repairers for NEB ovens under warranty. But as you moved into the house with the oven in the guarantee if under 1 year old does not stand unless the previous occupiers left you the reciept.
Experts Number is 0870 90 99 100.
Or just put a Post code up or look in the directories and i’m sure an independant repairer will be able to sort a part out.
Bit of info on the oven:- Sold by B&Q, Manufacturered in Italy by a company call NARDI Electrodomestici SPA.Regards
Woz
October 7, 2004 at 10:58 am #117586admin
KeymasterRe: NEB Oven – Broken
Thanks guys this gives me a bit of a head start, I will see what I can dig up with the appliance care people or the manufacturer. any recommendations on agent / firm to do the repair. We live in the Derby, Derbyshire.
October 7, 2004 at 11:08 am #117587woz
No problem at all always here to help.
There’s a firm called Safeway electrical down there who carry out some work for Expert Appliance Care
They are based in Ilkeston but cover all Derbyshire.
Hope this Helps
Woz
