Re: Neb Vicenza Cooker failed element
I have removed the original rear element ( power isolated!) which was just allowing cold air to be blown over it and it has a part ref on it of :2191 347 R IRCA 230V/2300W
When I put a multi-meter across the removed elements live and neutral elements I get no through resistance reading ( assuming it’s blown ).
I then applied the multi-meter to the then exposed cooker wired terminal spades I get a resistance reading when switching the fan assist knob off an and on which tells me the wiring in the cooker is just fine.
This sound ok ?
I will order the replacement part via email.
