NEB Vicenza Mirr oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum NEB Vicenza Mirr oven
  • #8636
    We’ve got a NEB Vicenza Mirr oven that stopped working…well the oven part did, it’s the fan assisted oven and the part that’s stopped is the “main oven with fan”
    It’s the 6th turn on the right-hand knob, a fan within a circle within a square, I checked the connections inside the top panel (with power off) and can’t see anything loose
    Has anyone any ideas or had similar problems with this type of oven
    Cheers
    Matty
    #129765
    Dave_Conway
    Re: NEB Vicenza Mirr oven
    Matty, when it’s in fan assisted mode is the fan running etc or does the whole oven go dead ?
    #129766
    The fan spins and the rest of the oven is fine, I can turn it to grill and it works ok
    #129767
    So basically no heat when in fan oven mode? Check the element behind the rear panel. Pull the plug first.
    If you are not confident, check Directories or Repairs@ for a UKW repairer in your area.
    woz
    How old is the oven???
    If its less than a year old then Expert Appliance Care do the repairs under warranty on 0870 9099100
    Regards
    Woz
    #129769
    Cheers lads for the help
    The oven is about 18 months old
    I’ll hopefully post you the end result, cos the wife is sick of using the bloody grill… 😳
    #129770
    Hello all, thankyou for all your posts. 😆 The cooker is typically out of its warranty, isn’t it always the case!!!! 🙁 we don’t even know what the element looks like or where to find it so we are stuck like the perverbial river boat and paddle!!!! Gonna try to get a hold of the directories for repairs. I cant stand the smell of deep fried food so me and my other half are not seeing eye to eye at the moment seen as he threw the manual away in one of his infrequent spring cleaning frenzies, this is why women do it and men shouldn’t:lol: !!! Ar well wish him luck finding the problem, he is gonna need it. Thanks for all your help
    #129771
    Right lads you’ll be glad to know I got it fixed, a new element from a local place in Leeds (can’t remember the name), £32 incl VAT
    Thanks again for your help :wave:
